When I brake, lights dim momentarily.
rxm6
Car: '93 240sx
When I'm at lower speeds, when I press on the brakes my lights will dim momentarily. I'm thinking voltage regulator, but I don't know enough about my electrical system yet to start making any conclusions. Ideas?
audtatious
Could be the battery or alternator. With the car running you should see 13.6-14.5v (tho I would usually expect 14v+ from the alternator) at the battery if the alternator is good.
maxhopper
Car: 02 Maxima SE 6spd
Most likely a grounding problem. I experienced the same thing; most notable with the head lights and the A/C or Defrost on.
Since I installed a grounding kit, I get much less dimming.
I would recommend cleaning the grounding points for the factory harness, and see if that doesn't help.
danielekfuj
Car: miata, rocket ship
I experienced the same thing, I had a bad battery.
But I would see if the less expensive options fix the problem first though.
