evildky »
https://forums.nicoclub.com/evildky-u13100.html
Fri May 28, 2010 9:47 am
the senser and sensor i the hardpipes won't make your car run how, the single wire goes to your temp gauge, the one that looks like an injector clip goes to the ecu for cold start enrichments
if the car si running hot, it can only be 1 of a few items
air in the system, you cleared taht issue we think
lack fo flow, this could be a bad thermostat, bad waterpump, clogged headgasket coolant ports due to crappy addetives, if you say you ahve rust int he system it's most likely addetive and not rust
lack of cooling to the radiator, a bad fan clutch or a damaged fan can cause this, also a crappy electric fan taht can't keep up if somebonehead tried a elec conversion
clogged cat is a possibleissue but should come with noticible power loss form the time you start the engine
