91Q4U »
https://forums.nicoclub.com/91q4u-u16822.html
Sun Aug 08, 2004 5:11 pm
DIY completed, and done so without "divorce court!" This was simpler than putting together those "assembly required" furniture pieces. Once again, thanks to everyone on the NICO forum, and we're on the road again!
BTW...nuQ...my belts also squealed and did so at higher rpm's as you experienced. I now realize that it was the belt being pulled around a pulley whose bearings were going out. All it took was time and it became frozen. Not fun.
When you changed your belts, were the pulleys free moving? Now, I'm not an expert gear head by any means, so you ought to ask the OnLine Mechanic, but I believe that as the car is run, and the pulley bearing becomes warm, it has the potential to not function properly if it's starting to "go south."
So, this completes (until the next surprise) another chapter in our "Q-files" and may the wind at the back of your Q not be your own.
Q-on everyone!!!______________91Q4U
