OM3GA »
https://forums.nicoclub.com/om3ga-u39603.html
Sat May 02, 2009 9:06 am
Ive been wondering this for quite awhile, And im sure it should be cleared up amongst others as well. When doing your alignment with coilovers and having camber plates (front of vehicle obviously) With the camber plate set to 0 what do you set the coilover to where it attaches to the spindle or knuckle. I usually set the camber plate to 0 set the bottom to 0 and then go back and adjust the camber plate to where id like my camber to be.
Now that ive lowered it a lot more im sure i wont be able to do this now so what is the best setup for proper movement of the coilover and knuckle? should i set it to around -1 or -2 camber at the stock adjustment location and then adjust the camber plate to where id like camber to be.. Im worried about how the angle of the strut is and how that affects travel whether it be straight up and down on the knuckle or at an angle on the knuckle... Does it matter? The pic kind of shows what i mean.
Im going to be setting the front camber to -3 degrees.
Modified by OM3GA at 12:16 PM 5/2/2009
