Lucky you (About oil consumption)!rsg123 wrote:I do not have oil consumption issues. I try to have the oil changed around every 3500 miles (non synthetic).
Lots of threads on this topic.WhoDey456 wrote:I use synthetic, I was wondering when (how many miles,intervals) does everyone like to get their oil changed?
So, you think the oil change should be strictly based on miles driven - even if that means change oil every 2.5 month or every 2 month, consider some of us drives a bit more?szhosain wrote:
My suggestion: change the oil and filter every 3750 miles or less ... whether you use synthetic or dino oil is not a factor then.
Z
Yup! "Clean oil is the best oil".M45Runner wrote:So, you think the oil change should be strictly based on miles driven - even if that means change oil every 2.5 month or every 2 month, consider some of us drives a bit more?
Actually - the dumpy dino oils kinda do need to be changed especially in extreme conditions cars today are put under. It's not a bad idea if that's the case. Once you start using oils with different additives packs you can essentally not have to change the oil till it wears out and that is determined by oil analysis. I think mcrews has an oil analysis sheet posted in the Q45 forumWhoDey456 wrote:now people on the other thread under "oil filters" are saying they change their oil every 7,500 or 15,000 miles which just seems nuts! But I do think the change every 3,000 miles thing is kinda bs! just for quick lubes and jiffy lubes to get more business! just my opinion tho. I live in Iowa and the winters suck here, so Im going to go with Mibil 1 0w-30
