psfod3 wrote:I agree but most dealers are pushing changing the cvt fluid at 30,000 to make money.
The 'Premium' service plan recommends fluid changes at 30,000mi.
CVT fluid is a little expensive at ~$15 US /quart (500ml). You need approx 7.8qt (7.5l) for FWD models or 9.2qt (8.6l) for AWD. Not sure how this compares to automatic trans fluid changes, but you are easily looking at +$250 US for a CVT fluid change including labor. Note: there are no filters to change within the CVT so fluid changes are simply draining and refilling.
psfod3 wrote:Is there a seperate differantial fluid and transaxle fluid that has to be changed?
On FWD Rogue's the transmission and differential are all in the same case so only one fluid change is required.
On AWD Rogues, you also also have separate transfer case (bolted to the back of the CVT) and rear differential fluid. They use commonly available 80W-90 GL-5 gear oil. The recommended change interval for these fluids:
Schedule 1 and 2:- Inspect every 15,000mi (24,000km). Change if required ie. dark or discolored fluid.- If towing, change fluid every 60,000mi (96,000km)
Premium Maintenance Schedule:- Change every 30,000mi (48,000km)
