when do fuel lines need to be upgraded?
Flicktitty
Car: 1989 Nissan 240sx 2JZ-GTE Swapped
1994 Toyota Supra
2019 Lexus GX460
1992 Lexus SC400
Just looking to see who has larger fuel lines and at what horsepower did you upgrade?
i'm planning on going with a Single turbo on my 2JZ over winter with a larger Tq converter, and i'm assuming the cars' gonna make about 450-530RWHP depending on what fuel i'm going to be using.
i'm just wondering if this will be ok on stock fuel lines or if i should go with a larger line and if so what size -6an? -8AN?
thanks guys.
heartofaskyline
Car: 1992 hatch, 1993 sr20 coupe
-6an are the same as stock lines. stock lines should support 600 at least. i have a friend that supported over 600 on his sr. he ran into fuel problems from the walbro not being able to flow enough fuel, so stock lines and a second pump should be fine for those numebr
