sil80drifter wrote:How do waterpumps go bad? The one on the KA-E is basically blades and a pulley connected by a rod, so what is there to go bad?
I have heard of some blades actually deintegrating due to bad coolant (red instead of green), but other than that.... Could you guys describe what exactly goes bad in them?
sil80
When mine died, i guess the bearing and seals gave out. I could tilt the rotating assemby (blades/shaft/pully) off its axis. It was pretty nasty. I guess vibration and wear killed the bearing or bushing inside and let the shaft move around and kill the seals. But it didnt give out until i pulled into my driveway, so props to nissan for that
