Zwicked »
https://forums.nicoclub.com/zwicked-u65277.html
Thu Mar 11, 2010 9:20 am
Pull all the connectors with the spring clip and see if they are corroded. Sounds like and intermittent electrical connection to me. The ones to check are: CAS, PTU, Injectors, Coolant Temp Sensor, AAC, FICD, Air Regulator, TPS, and MAF. Scrape all the corrosion away you can, and then apply some good contact cleaner. Essential that all components have a good connection.While you have them off the injectors, test the injectors with a multimeter to make sure they are all in spec. They should measure 10 to 14 ohms.
Also, the other post is correct. Make sure you are using the NKG Nissan recommended plugs. Unless you are running extreme horsepower no other plug will do as well as the stock ones.
Bolts missing on balance tube? YES any vacuum leak is bad and make sure all your CP's are bolted down. The engine and connections need to be meticulous!
