pulsar gtr »
https://forums.nicoclub.com/pulsar-gtr-u1034.html
Sat Mar 13, 2004 8:41 am
Definitely replace your rear main seal, these are known for leaking when they get a bit old. They are cheap and they will save you a lots of work in the long run, It is located behind your flywheel.
I can get you the gasket for around 15-20 dollars shipped from Canada to your place, but you shouldn't have a problem to find it locally, they are the same as the 1987-1990 pulsar ca16de or ca18de.
Don't forget to machine your flywheel since you are change the clutch.
PULSAR GTR
