When car engine is on, i get a rough idle. When the car is
cellogig
in reverse or drive the rpms drop and i am losing power to the car engine. Giving the car more gas helps to maintain power but letting off the accelerator reduces rpms and power to the engine. the engine runs rough and sputters after i engage the shifter into drive or reverse.semms the car loses a lot of power when i engage it into drive or reverse. Large amount of shaking and vibration when the car is on. any ideas thank you
Is this because of a weak battery. I change the ignition wires and plugs.
AE86Gio15
Car: s13
cellogig wrote:in reverse or drive the rpms drop and i am losing power to the car engine. Giving the car more gas helps to maintain power but letting off the accelerator reduces rpms and power to the engine. the engine runs rough and sputters after i engage the shifter into drive or reverse.semms the car loses a lot of power when i engage it into drive or reverse. Large amount of shaking and vibration when the car is on. any ideas thank you
sounds like misfiring, check to see if you installed the ignition wire incorrectly.
94_240sx
Car: 94_240SX
Can you pull out the wire one by one and see which cylinder is not firing? When you pull out, if there's no difference that cylinder is not firing. If you pull one of others, the engine is going to die or run really rough.
Nick240sx
Car: 2009 Ford Fusion SE Sport
are you sure that you connected the wires in the correct order on the distributor cap, make sure the rotor and cap arent retarded or accelerated.
cellogig
Yes i checked the wiring. everything is correct.
This was happening before i changed everything out. I thought this would improve the low amount of rpms and rough idle.
cellogig
checked everything is correct.
Nick240sx
im assuming you changed the spark plugs also. just making a check list.
Have you checked your maf? Throttle body isnt caught up is it?
94_240sx
Car: 94_240SX
cellogig wrote: This was happening before i changed everything out. I thought this would improve the low amount of rpms and rough idle.
Can you tell if it's running on 3 cylinders or not? How about oil on spark plugs? Did you pull them out and check?
cellogig
94_240sx wrote:Can you pull out the wire one by one and see which cylinder is not firing? When you pull out, if there's no difference that cylinder is not firing. If you pull one of others, the engine is going to die or run really rough.
tested this, everything is ok
lose of power to engine happens when car is engaged into gear.
cellogig
yes oil on the first plug. Had a valve gasket changed a month ago. Still oil on the first plug..might be because of left over oil in the chamber.
the car ran smoothly this morning and since the gasket change. then just started to run rough after 2nd use of car this morning. I thought changing the plugs wires and fuel filter might help.
cellogig
Nick240sx wrote:im assuming you changed the spark plugs also. just making a check list.
have not checked the maf or throttle body. will go and check this.
cellogig
im going to take it in to my mechanic. i just cannot figure it out. maf is fine. wiring and plugs are correct.
thanks for everyones help. will report back. its going to be something simple im sure.
Eikon
Car: 71 240z, 93 Supra TT
Have you changed the fuel filter recently?
