wheels?
240sxGT
Car: 97 Nissan 240SX SE
98 Nissan Maxima SE
93 Subaru Imprezza
Ok I have a 97 240sx se.I am looking at a set of 5zigen rims 17X7.Only come in 42mm and 48mm offset.
Using the offset calculator, I believe I will need to use a spacer, 10mm to keep the stock clearence to the shocks. But are spacers safe/good/bad?Thanks for your help.:help
yeswepromise
spacers are fine.
Exar-Kun
Car: 2005 350Z
spacers are not fine. do some searching! we discussed the spacer issues many, many times, in great detail. suffice to say, spacers are not a good idea, but sometimes become necessary, and if so:-get hub-centric spacers, and use longer wheel studs(NISMO makes them)
-chet
240sxGT
98 Nissan Maxima SE
93 Subaru Imprezza
Thanks for the input guys
