wheels??
law
Car: 96 240sx
what size wheels do you run I'm looking at getting some but dont want to rub.I'v seen 18x7 on a V is 7 the best without rub..Alittle help thanx
NY.AD.MAN
Car: 2011 Nissan Altima Coupe 2.5S (Navy Blue Metallic)
Gone... 2007 Nissan Versa S Hatch. 6 Spd. Blue Onyx - Multiple Upgrades
17 x 7 with 205 40 R17 Tires
longo
Car: 2007 Versa SL, CVT
I found this great little site to check things like OEM tire specs vrs' change overs to different sizes...
http://www.miata.net/garage/tirecalc.html
Ever Victorious
Car: '08 Kia Spectra 5
'73 AMC Hornet
When I get my 3-season tires this spring, it will probably be 215/45/17's on 17x7 rims. -0.6% deflection on the speedo (60 MPH on speedo is actually 60.4 MPH)
This size will be as close to stock diameter tire as possible... the set NY.AD.MAN has selected changes the overall drive ratio due to a shorter overall diameter. His tire choice nets him greater acceleration, a lower top speed, and likely poorer fuel economy. +4.1% deflection on the speedo (60 MPH on speedo is actually 57.5 MPH)
NY.AD.MAN
Correct, EV
Well... a little off...
I've only noticed a .5mpg difference in the last 4 fillups and my 0-60 time has improved by .7 seconds, which is good because I spend most of my time in the city...
However, I will be switching to 215 40 R17 giving me a .1% differentiation (error rate) allowing me the same performance and gas mileage as stock because I want a wider tire for better handling.
Ever Victorious
'73 AMC Hornet
215/40/17 is a slightly less common tire size.
For example, Discount Tire sells 19 different models of tire in that size.
Compare that to the 215/45/17, where they sell 36 different models.
dopey
Car: 06 Nissan Tiida
i was told to go with 35 profile on 18s but using that calculator i think 40 profile is a better match35 looks stupidly skinny
im going to try 225's on my 18x7.5's hopefully i dont experience much rubbing
NY.AD.MAN
dopey wrote:i was told to go with 35 profile on 18s but using that calculator i think 40 profile is a better match35 looks stupidly skinny
Just remember that your tires will stick out from your rim with 225's and the wheel is already wide enough to just barely clear the wheel well...
lain
Car: 2007 Nissan Versa S
I'm still trying to decide if I should get another set of 15's to replace the steelies or to go higher. Either way 17 is the highest I would go...I would rather have 16's. The 2 companys I'm looking into is WorkWheels, the expensive OMG wheels, or Sportmax Wheels, the inexpensive OMG wheels. If you really want to put some cash down go with Buddy Club streight up JDM.
shreqboi909
Car: '98 ej8 R.I.P 07 nissan versa/tiida
i had 17x7 on my V
it had 225/45/17 in the front
245/40/17 in the back
didnt rub at all and gripped the road like my life depended on it
lol
