Stoneage_Turbo »
https://forums.nicoclub.com/stoneage-turbo-u133.html
Sun Sep 15, 2002 9:26 am
"stock is never the way to go....whatever rims a car comes with, there will always be a better aftermarket one.unless of course its a porsche, ferrari, lambo, etc....."
find me a wheel that is lighter than 15lbs , stronger than stock ,is hubcentric with correct offset, corrcet bolt pattern and no bigger than 15 inches no smaller than 14 , pretty hard huh ? only a handful of wheels out there that fit that critera (none i have found here in the US) espicly when your bolt pattern is 4x114.3. now if we are talking steel wheels then yes your right most anything is beatter than steel .
weight is a big factor , you play with the weight at that whell you change alot on the car , steering feel being the biggest , off the line acceleration being second, even the slip angle could change
