The rears may be too wide. Remember in general you cannot fit as wide a tire on the front as you can the rear because the fronts need room to turn. This is also why most front fenders have a larger or higher arch than the rears.jerseyblood wrote:Yes I understand staggered fitments, I also have a Mustang with a staggered fitment. What I meant by my question was why all fronts and not all backs? For example wouldnt you want the fattest tires all around instead of skinnies? I can understand the weight difference but that wouldnt be too much. Thanks.
