LongBeachCoupe wrote:i believe if you go from 16-20s when the speedo says 60 you are going 68 i THINK
Where did you get this information?
In general the whole concpet of plus sizing is the increase the diameter of the rim while reducing the sidewall height of the tire - so that the end result is the same diameter.
When you get to the larger rim sizes 20" and above that is where you generally start increasing the overall diameter. Any good fitment should be as close to the original diameter as possible.
