Postby
SmithSR »
https://forums.nicoclub.com/smithsr-u5241.htmlSat May 24, 2003 11:18 am
got pics of wheels? is it clearly marked *VIA* ?? the 690kg is most likely the max load rating. most wheels are stamped with the load rating somewhere on the wheel, some are harder to see than others.
I'll assume you immediately got out your torque wrench and checked the rest of your lug nuts at all four corners just to be safe.
Postby
Rex »
https://forums.nicoclub.com/rex-u6324.htmlSat May 24, 2003 11:18 am
Well, tomorrow I'm off to see what they plan on doing about the missing lug. All the lugs are the "Gorrila" type with a special socket, so they'll need to either get the exact lug or replace them ALL.
LaureltheQueen wrote:nice pinstripe....
Thanks on the stripe . I've thought about removing it, but I wonder if the mark the 9 yr old stripe would leave behind would look any better??
