SmithSR »
https://forums.nicoclub.com/smithsr-u5241.html
Thu May 29, 2003 6:27 pm
Hmm, I've seen this happen before... My old *cough* civic, when I had it and it was brand new, with OEM firestones, had a shake at about those speeds, below or above and nothing. I mounted some good aftermarket wheels/tires, and the shake was gone. This could be a balance issue, as they are usually intermittent, occuring at only certain speeds. It could also be a problem of tire construction. Although an out of round tire(however slight) would most likely be felt much like a bent wheel or a flat-spotted tire would, although maybe not to the same degree. Falken Ziex aren't the most expensive tires for a reason, not to say they are crap, because they aren't. I'm curious if you made a typo when you mentioned alignment??
