ncs14 wrote:alignment will not do it.....had it aligned a few times by different people and they couldnt fix it....the only thing i can think of is....the camber in the LF was off more than the RF so one shop put a camber bolt in the LF to set it the same.....would an aftermarket camber bolt on one side and a stock on another cause it to do this....because it looks fugly to the point that im thinkin about buying a shell and swaping everything over.
toss those camber bolts out in the trash and get some camber plates. way easier to use, and work 10x better than camber bolts.
like I said, judging by your pics, your camber does NOT look symmetrical.
