Amgberg wrote:TDot wrote:
Doesn't that make it more prone to pop with a hard hit?
Not always, that's why we use extra load tires more psi will keep it firm. 245/35 is actually a mild strech. But if your tire is under inflated when strech yes that's when bad things happen to much softness in the tire when u hit a pot hole the rim can hit and cus a flat. So I run 60psi firm side wall. Some guys run 40-90 psi depends on how much strech and size of wheels. 245/35 on 10.5 I like to use 60psi but my friend run 40psi and never had a problem as well. My tire is a 95 load 1521lb each tire that play a role also.
what brand of tire is that?
my tires are 100XL with 1,764lb load and my max psi is only 51psi... I'm running them at 42psi to make it a little firmer for the sidewall. you know people running 90psi??
