wheels? how much off set?
mschram
Car: 1989 240sx with silvia s13 right hand drive conversion and sr20det
I recently purchased an 89 240sx. it has an sr20det swap already. im wanting to run a 275 40 17 in the rear and a 225 40 17 in the front however i cannot find anywere what kind of offset i need for the front or the rear any ideas would be help full.
thanks.
mudvayne9790
Car: 240sx 93 Hatch
this is a very frequently asked question and you should search on the forum. Their are a lot of threads about this so i suggest you go and look for them. But to help you out the rule of thumb is the closer u get to 0 offset the better although it also depends on your taste. Go to rimtuck.com and type in 240sx and looks through the pictures and see what offset you like best.
Good luck
mschram
thanks for the help and i have researched the only difference is that i want wider tires to get my 500 hp to the ground with a close to zero or zero offset im stuck at no wider then a 235 tire due to clearence so im wanting to do an offset to allow for wider tires and i cant find any threads out there on that one due to the fact that its not very common to go old school wide tire with a tuner.
AAV240sx
Car: '89 240sx ka24e-t
E39 M5
You can run what Broadfield use to run on his coupe which is 18x10 +44 275/35... link
mschram
thank you sir that was exactly the information that i needed now that i know they will fit i will order them ill post pics when i get them on
simmode1
Car: Red '95 S14
There's not alot of 225/40/17 tires on the market. Between the more common 225/45/17 or 235/40/17, I'd pick the 235's.
adrianfromthecastle
Car: 1992 Nissan 240sx
if you want to run 275's, you gonna need a some high offset wheels unless you're planning on doing fender work. What's the plan on camber?
oh and AAV240sx: cute sig lol Image
AAV240sx
E39 M5
Thanks, yeah she's pretty cute :D . So is yours.
240TKE128
Car: 1990 240sx HB
2011 subaru outback 2.5i limited
I myself Plan on using 225/35/18's in the front and 245/35/18's in the rear however my question is if i drop from the standard 45 offset to a 35 offset do you think that drop will be enough to fit these tire selections for clearance.
AAV240sx
E39 M5
If it's on eight and nine inch wide wheels with 35 offset, you need to roll you fenders with those tire sizes, and a little bit more camber than stock depending on how low you are. I know cause that's what I run except on 17's
240TKE128
Car: 1990 240sx HB
OK Thanks, that gives me something to think about the wheels are about the only thing i dont have figured out yet.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
I use a 275-40-17 in the rear with a 17x9+35
240TKE128
Car: 1990 240sx HB
Wheels are definitely not my specialty Ive been having a hard time finding any that are the size i want, even going to manufacturers sites cant seem to find exactly what i want. I wanted to have 8 wide in the back but the only time i can seem to find that is on an 18, what id prefer is to have a 17x7 in the front and 17x8 in the rear. Any suggestions where to start looking?
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
17x8 or 9 front, 17 or 18 9-10.5 rear. Check out the offset threads.
