msaskin wrote:Very interesting indeed. Best option so far looks to be the BFG DR's in 225/50/15 on my spare set of stock alloys. Do you happen to know what size slick would fit on the stock wheels? (ET Streets most likely)
~matt
I wouldn't go any bigger than a 225 width on a 6.5" rim. MT doesn't really have anything in a 15" diameter that will fit on the 6.5" rim. I will caution you about running diameters lower than 23.5" When I ran the 22" slicks they were making me hit my top speed limiter because of the effective change in gear ratio. Bouncing off the top speed limiter starting about 1220' mark.
FYI.... 225mm is 8.85 inches
