fueler »
https://forums.nicoclub.com/fueler-u54519.html
Mon Feb 16, 2009 7:07 pm
well they have to be 6 on 5.5 lug pattern, at least 16" (some 15s fit and some dont) and the center bore has to be at least 4", and the backspacing should be 3.5 to 4 inches ~BUT~ rather than getting you started on numbers, in my opinion the best way is to just go to your local, family-owned tire shop (corporation/chain tire shops are BS), or off-road shop, and have them test fit a set of rims and tires that works. You need to let the car down and turn the steering wheel at full lock to each side and see if it touches. Ideally, the tire will only be a few millimeters from the strut (but dont worry it wont touch) and for this reason, i do not recommend buying tires/rims online!
