240sxdominos »
https://forums.nicoclub.com/240sxdominos-u22876.html
Sun Feb 25, 2007 12:13 pm
I just got my tires (215 45 17 front 225 45 17 rear) mounted on 4 17x9 +35 wheels and tried mounting a front wheel. I put it on and found the stud was too short to mount the wheel, I assume this is because I need a spacer( or just the longer studs included), but I had originally thought that the spacer(or just longer stud w/ the spacer) was only required for clearing coil overs. So my question is, should these wheels be fitting with the stock length studs on a stock suspension or will I have to wait for my spacers to arrive? Also, any ideas if this will be a problem for the rears? Car is a 1990 240sx with stock suspension. Thanks in advance for the help. -John
Note: coming up with search combinations is harddd, but yes I did search.
