Wheels: Compatible Bolt Patterns
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
skyl4rk
Car: 2009 Nissan Versa Base Sedan 1.6
I would like to put 14" or 15" wheels on my Base and will be headed to the local junkyard to see if there are any available. A couple of questions:
1. What wheels will fit the Versa Base bolt pattern? I assume older Sentra wheels will fit, will any Nissan wheels fit? Will other makes fit? What bolt pattern should I be asking for?
2. Do 15" wheels fit on a Versa Base? Will I need a special tire profile?
As you can tell I know very little about buying wheels.
tnx
KimberKenobi
Car: the Camel
The Versa base has the same body parts as a Versa sedan so 15" wheels with stock tire size 185/65-15 would fit. The bolt pattern is 4x113 so any 8-hole pattern should fit (they are usually 4x100 and 4x113 together). As for earlier makes of Nissan... no idea. But I do know someone got a set of Sentra SE-R wheels which fit, but you'll want to make sure the bolt patter is 4x113 on any that you purchase.
Good luck digging around!
blindsnyper
Car: 2007 versa
hey kimber 4x114.3 (not 113) aka 4x4.5
14 i dont think will fit.any 4 lug nissan will fit, i dont know what else 4x114.3 is kind of an unpopular pattern
biggie
Not all 4 lug Nissans will work. Only newer Sentras are 4x114.3 (B15/B16). Newer Altimas should work. And doubt 14s will clear the brakes.
blindsnyper
Car: 2007 versa
really, i did not know that, hmmm
biggie
This should help:
http://www.discountedwheelware...e.cfm
It isn't updated with all the newer models though. Couldn't find an updated chart anywhere.
1_Sleek_Versa
Car: 08 Nissan versa SL
14's do not fit, no caliper clearance. Tried it before buying winter radials.
Sentra SER wheels fit. They are heavy as hell though and for the price just get a package on tirerack or another company.
"2. Do 15" wheels fit on a Versa Base? Will I need a special tire profile?"
Of course they fit. Do you have 14's on your Versa? Just asking.
D3stro
blind_snyper wrote:hey kimber 4x114.3 (not 113) aka 4x4.5
Previous Honda Accord had 4X114.3 bolt pattern from 1990 to 2002. Even Prelude from 1992-96. Mostly, 4 x 114.3 was common on Nissan but less on other cars company.
Return to “Versa Technical Discussions”
