kmiles »
https://forums.nicoclub.com/kmiles-u181661.html
Wed May 29, 2019 12:49 pm
I went though a similar discernment and ended up coming to the following conclusions:
- I ended up moving to 20" wheels with new Michelin Pilot Sport AS3+ tires (245/40ZR20) on new Infiniti wheels. That move meant that the speedometer was still accurate and mileage was accurate with no other modifications if your 18" tires are 245/50R18. I love the wheel/tire combination and it is loads better than the Primacy MXM4 - which I truly disliked. It also looks so much better! I now have about 5000 miles on them and have zero complaints. I'm working in Seattle 3 or 4 days a week and their roads are in bad shape and you feel it with the sportier wheels and tires. Everywhere else, where the roads are in decent shape, the drive is awesome.
- I was thinking about upgrading the brakes from the standard ones to the sport brakes. However, if you do that, the 18" wheel set will no longer fit and you will have to swap out the spare in order to clear the larger sport brakes. I was thinking about doing it more for looks that anything else, but once I studied it out, ended up sticking with the standard brakes. I don't take the car to the track and it stops fine as is. Once it has reached a point that I need new brakes, I plan to go the Brakemotive route again.
I hope that helps you in your decision. Please let me know if you have any questions.
Kerry
