93jdirty’ wrote:it will fit whats the offset?
I am not too sure what the offset is. I just did a search on Discounttire.com and is said they would fit. Here is a link to the wheel, I think they are 40mm offset- http://www.discounttiredirect....06112
J30inthe sun wrote:http://www.miata.net/garage/tirecalc.html
Speedometer reading with non-stock tire is 1.6% too fast.When your speedo reads 60 mph, you are actually traveling 59.0 mph.
Tire Size Comparison
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference215/60-15 5.1in 12.6in 25.2in 79.0in 802 0.0%245/35-18 3.4in 12.4in 24.8in 77.8in 815 -1.6%
Modified by J30inthe sun at 7:37 PM 12/3/2008
Thanks for the link. That is actually the site I looked at to compare the tire sizes. My main concern is if the width of the tire will cause any rubbing.
gr8scott72 wrote:Those look like Falkin Ziex tires. If so, don't expect very long life out of them.
That is ok, Falken tires are relatively inexpensive and handle very well. I have had them on 2 S10s and my old Accord. They are my tire of choice for the price.
