bruce.weiland wrote:When a tire (lets pick a 255x50x16) spec lists wheel widths from 7" to 9", obviously a wheel wider than 9" would be difficult to mount and might cause bowing up away from the ground in at the center of the tread. A wheel less than 7" might roll the edges of the tire up off the ground.
Yes, yes, YES!!!! Thanks for understanding the above issue!
People always assume that the wider the tire they put on their car, the larger the contact patch area, the better the lateral acceleration, the better the handling, etc., they think they will get. In most cases, they are wrong if the tire does not match the wheel properly!
Usually, the tread width, section width and section profile changes, that result by using the wrong width tire for the wheel width, can have very unexpected results. The VIP "look" of stretched tires is a fad that, I hope, passes sometime soon.
Sometimes, people try to compensate for mismatched widths, by increasing or lowering tire inflation pressure. These have the side effect of changing the load index of the tire, and, in some heavier cars (like much of the larger Infiniti line), lowering the pressure too much can be dangerous - tire failure under speed or stress (hit a bad road bump and blow out the tire!).
bruce.weiland wrote:What would be the differences in handling, steering response, etc. for this same tire, on a 7" wide wheel and a 9" wide wheel???????
The answer, I think, is that "it depends" on the situation. (You might get away with some minor degree of mismatch beyond the limits - the worst I would consider is having a wheel that is 1/2" too narrow below the tire limit. Ideally, I would never do even that.)
Your question, is, of course, a bit different: "Stay within the limits, but what is the difference between the two extremes".
What little I know: in certain cases, with hard cornering, and incorrect tire inflation pressure, you could have tire separation from the wheel when the profile changes under stress. In some cases, with very soft sidewall tires (think Z rated), you may end up folding the tire over or not having the tread sit flat on the ground as much as the suspension allows. You may actually end up with less lateral acceleration maximums that you think you have.
FWIW, I have not done any reading on the specific answers that may apply to the above scenario (i.e., wrong width wheel for a specific tire) since I do not plan to ever be there. Maybe one of the engineering types (Q45tech?) can answer the questions a whole lot better!
Z
