Wheel weight vs acceleration
Q45tech
95q45_97cobra
Car: 1997 Ford Explorer (5.0 GT40 Cobra), 1992 Infiniti Q45, 1995 infiniti Q45 1985 Nissan 300zx Turbo,19
hello, i just bought a 1995 Infiniti Q45. The car was wrecked and had been sitting for a year when i bought it, im not sure if the transmission had any fluid in it because the radior was crushed, so i replaced the radiator and put 6 or 7 quarts of ATM Mercon 5 in the transmission and i moved it off the trailer and the next day the car wouldnt move in foward gear but it will grab and go quickly in reverse gear. what do you think could be the problem? please email me at,
[email protected] Ryan D.
qship96
Car: 1996 Infiniti Q45
how many times have we seen this post already?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
qship96 wrote:how many times have we seen this post already?
At least 3.
95q45_97cobra
If someone would answer the question, i wouldnt keep posting it.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
It has been answered.
Why do you think no one has answered it in a way that met your expectations?
95q45_97cobra
Ok, If the car wasnt in a accendent, what do u think could have happened?, I remember what you told me when i first posted, but since i dont know enough about these cars i wanted to know if the seals in the transmission could have shrunk from sitting for a year without being run and being low on transmission fluid in it?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Fix other known problems first (like no engine fan or clutch}) then you can proceed to AT diagnositcs and we can determine what has failed, or even if fluid fill is correct. Your porblem might be cavitation, but how can we tell in the car's present state?
95q45_97cobra
Ok, tomorrow im am going to put the fan and new clutch on it, and let it run for a while and see if any thing changes,When i checked the fluid cold, it was like half way up the stick, but i was told that it holds like 10 or 11 quarts. Is this correct?
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Please do not hijack threads like this! Next time posts will be simply deleted and you can bump your other thread. I will see if I can find your other threads and we'll go from there.
Tech posted an article and the resulting posts have nothing to do with this topic!!!!!
Edit: thanks tech for the sheet, im going to read more into it once I get a bit more time.
