wheel weight
D Money
Car: driving illegaly
my stock alloys weighed about 35lbs, i was shocked when i weighed my 17x7.5 215 45s yesterday and discovered it weighed 50 lbs . are my oz rims, crappy, heavy pieces of junk, or should i expect that much weight gain?
turtl631
Car: S14
most tires that size weigh over 20 lbs, and id guess your wheels are somehwere between 16 and 20 lbs. 50 seems like a lot though..
SmithSR
Car: 240sx
You should expect that much weight gain in larger sized wheels that are one piece pressure cast or similar(cheap method for mass production, not necessarily a bad process, just not cutting edge technology)
The only way around it is to invest in (smaller) forged lightweight wheels, or stick with OE wheels.
I use 15" wheels from the '80's, until I can convince myself to buy some forged 17" Fikse in black satin.
Exar-Kun
Car: 2005 350Z
or gram lights
lol Lighter=better...
usually in the world of wheels you can go a few ways1.bigger2.lighter3.cheaper4. stronger
pick any 3, IE a bigger(say 17") stronger and lighter wheel WONT be cheap..
you can find cheap strong big wheels..but they're heavy..wat
likewise, larger, cheap light wheels exist, but they use poor materials or casting tchniques that makes them weak
strong, cheap, light wheels are ususally smaller...
etc, etc-chet
SmithSR
Car: 240sx
Exar-Kun wrote:or gram lights
Yeah good call..
Gram Lights 57PRO 17x7 +25 / 36mm rim depth17x8 +25 / 49mm rim depth
is as radical I ever hope to be.
Exar-Kun
Car: 2005 350Z
word. I ran the gram lights 17x7.5 30mm offset..
fits coilovers, Z brakes, and 225-45-17 sticky tires with ease -chetI WANT A JDM GIRLFRIEND! :p
