Wheel torque specs
RT22
Car: 1991 nissan hardbody
anyone know? I have the chrome wheels which I hear can work loose if not torqued right. I just did a back yard rotation and tightened with 4 way Backyard, (floor jack one side rotate front to back). But i know on my old Z the aluminum wheels had different specs than steel or chromed have. Anyone know?
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Check out the service manual or manual that came with the wheels: http://www.nicoclub.com/FSM/
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
80 ftlbs.
RT22
Thanks rev 80 ft lbs it is.
PEZi
yeah.... i use 80 for just about everything...
RT22
Yeah my Z was 80-100, but it had aluminum wheels, and was told by a few that over torquing or not torquing evenly on aluminum can lead to rotor warpage as the wheels heat and cool cycle can really make the alum. wheel distort and cause rotors to warp. Which was a problem on the 90's Z's. Mine warped 2 times but with proper wheel torque it never happened again.
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
100 is too much. Nissan threads are soft and are easily pulled. I'd stay around 70lbft myself.
