Wheel/tire Compatibility for 2012 Rogue
MelanieeeC
Car: 2012 Nissan Rogue SV
I recently got a 2012 Rogue SV and am looking for winter tires/wheels for it.
A friend of mine offered me their winter tires from their 2018 Rogue, 40300-4BA0B OEM wheels with 225/65/R17 tires (GEN15-50277D Tires).
Will these wheels/tires work on a 2012 Rogue? From what I've looked at online, the aftermarket rims used for a 2012 and 2018 Rogue are identical part number, but they're saying that the OEM rims are not compatible? Why is this?
phmichel
Car: 2013 Nissan Rogue S AWD
2017 Nissan Quest SV
MelanieeeC wrote:
Wed Sep 15, 2021 8:15 am
See if the attached file helps...
I have a better version in an Excel spreadsheet but can't attach it here...? You have to watch the wheel offset and make sure the calipers will clear.
FYI - They should fit, but you'll have to confirm. I have a 2013 Rogue and have been running 18" wheels on it from a 2009 Murano since I got it 7 years ago.
casperfun
Car: 2009 Nissan Rogue SL AWD - Indigo Blue
Radius is 17, wheel is 17 = compatible.
:poke:
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
casperfun wrote:
Fri Sep 17, 2021 3:34 am
:poke:
LOL you mean diameter right; radius 17 wheels are (34")
The site probably says not compatible because of the TPMS difference?? Pretty sure the wheels fit
casperfun
My bad. I was never good at geometry. Oh boy, I meant rim diameter instead of radius. I guess I don’t know what the R meant on a freaking tire. :facepalm2
macgiver
You were talking radians ...??? No , no ?
17 / 360 x 3.1416 times unity / 17 times Pi r2 + 2mm , " That's the euquation ...!! " , Roc
casperfun
macgiver wrote:
Fri Sep 17, 2021 2:23 pm
In turn this will produce 1.21 gigawatts to run a flux capacitor. :bowrofl:
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
casperfun wrote:
Sat Sep 18, 2021 6:49 am
Flux capacitors are a myth. It's the dual fretonators on the quad that cause real issues. :rotfl
macgiver
casperfun ,I know you have a supurb sense of humor when the posts start " loosening-up " :chuckle:
p.s. I got Ruk wrong - not Roc . Ted Cassidy ,( Lurch ) in Star Trek said "That was the equation !" and then helped Kirk out of the hole.
Return to “Rogue Forum”
