Wheel swap question 2007 G35 Sport to 2007 M35 Sport Wheels
bloomjg35
Car: no G yet.
I'm considering buying a new G35...and I like the OEM wheels on the sport model but when I was at the dealer, I noticed the M35 sport wheels on that car. I really like them. I've done some research is this is what I've found:
Both wheels are 5 lug 114.3mm spacing. From what I read, it appears that the G35 Sport wheels have a 35mm offset and the M35 have a 50mm offset.
Does anyone know if the M35 Sport dual spoke 5-star wheels will fit on the 07 G35?
Thanks,
JB
Rex
Car: None
bloomjg35 wrote:I'm considering buying a new G35...and I like the OEM wheels on the sport model but when I was at the dealer, I noticed the M35 sport wheels on that car. I really like them. I've done some research is this is what I've found:
Thanks,
JB
Need the widths of the wheels to know for sure (width and offset combine to let you know fitment).
That said, based on the information you posted (and the fact that they're both probably 8" wide), the M35 Sport wheels would be "sunken" farther into the wheel well and most likely rub against the suspension. Spacers would allow you to use them, but spacers should be avoided if possible.
If you choose to use spacers, do not use cheap ones. Quality hub-centric spacers should run you more than $100 per axle.
G_whizz
Car: 2010 G37 Coupe Sport
And...Welcome to NICO!!
