naed240sx »
https://forums.nicoclub.com/naed240sx-u28231.html
Fri Dec 22, 2006 8:17 pm
265s on 8.5s is not gonna fly. Yes they will fit, but that doesn't mean that it won't suck.
You are probably gonna shoot this down, but FN01RC's are your best bet I think.
18x9.5 all around with your choice of +12, +22, +35 and +43.
9.5s will fit the size tires you want far better, and no, the tires won't be stretched.
For the rear: The 9.5+43's will only protrude an additional 2mm compared to your current setup.
For the front: Since I'm not sure what kind of strut clearance you are dealing with, it would be hard to tell what offset you should go with.
Obviously, you will have fender clearance issues up front. RUN MORE CAMBER. I'm not telling you to camber fit, I'm telling you that -1 is like stock and it sucks. You can run -2 or more with good toe settings and your car will handle far better, and won't cause bad tire wear. This will help you to fit the 265s.
If 9.5 sounds too extreme for the front, there is also an 18x8.5, but you shouldn't run 265s on them.
As far as weight, you can't even find an 18x8.5 that is 20 pounds unless you go with a forged wheel, but the FNs are gonna get you the closest to that number.
Edit: The 5Zigen ProRacer GN+ is also another choice. They come in 8.5 and 9.5 as well, and in the same offsets.
spl has both of these.
If none of this sounds good, I will say the following:
1.) Definately consider 9 front and 9.5 rear as minimum widths2.) Run more front camber. It will help with grip and allow wider wheels and tires to fit.3.) Find out how much inside clearance you have front and rear.4.) Consider pulling your fenders. It's not really noticeable if done correctly and allows at least 15mm more clearance.
Modified by naed240sx at 10:31 PM 12/22/2006
