wheel studs
QX4954rr
Car: 2003 Qx4
anyone know were to buy replacement wheel studs. i need them to be a little longer trying to fit on 15" but i need to use a 1/4 inch spacer to clear the brake caliper i found out the oem ones are front 32mm 12x1.25 and a 14mm knurl rear is 41mm
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
Check with THE TIRE RACK.
selfguided
Car: 2003 Pathfinder LE 4X4
i found replacement studs (12x1.25 41.5mm) at advance auto for around $2/ea. they have many different sizes, im sure you can find a longer set there.
QX4954rr
Car: 2003 Qx4
does anyone know the knurl diameter is it 14mm for the front studs
