wheel studs
crash n burn
Car: '91 Nissan LE hatch
'93 Nissan Silvia UDSM
'92 Infiniti M30
so 2 of my studs sheared off while i was testing out my car, i took everything off, and popped out the remaining studs, but they could spin in the hub..should the holes the studs press into have grooves that lock in with the groves on the studs, or are they supposed to be smooth, i've never really looked before, but mine are smooth.
basically i think i need a whole new hub...fan-damn-tastic
94_240sx
Car: 94_240SX
crash n’ burn wrote:are they supposed to be smooth, i've never really looked before, but mine are smooth.
No, it's not supposed to be smooth.
crash n burn
'92 Infiniti M30
thought so
any tips on how to get the cap off to access the nut?
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
crash n’ burn wrote:any tips on how to get the cap off to access the nut?
Just get a hammer and a screwdriver and beat that ish off. That's what I did. Just buy new ones, they are cheap.
crash n burn
'92 Infiniti M30
yea..pretty crappy that im gonna go buy another 4 lug hub when im halfway done collecting 5-lug swap parts and z32 brakes
EnjoiNismo
Car: 93 240sx
Ok i hate to bump up a old post but i have the same issue. The inside of my hub where the stud is suppose to go is smooth. So when i put the stud in the hub, it does not lock and just turns. Is there any way i can get a oversized stud that will lock it in place. If not i suppose i can take off the hub and have it pressed.
EnjoiNismo
Car: 93 240sx
annnnyoneee?
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
same thing happened to me, I tack welded mine in place. However you can try other alternatives jb weld or something, but tack weldings definitely the best solution...
94_240sx
Car: 94_240SX
OM3GA wrote:However you can try other alternatives jb weld or something
JB Weld is not strong enough.
