Wheel Studs Longer than 60mm??
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
I was wondering if anybody makes wheel studs longer than 60mm? I used the search button but couldn't find anything....
sultan
why do you want longer studs, gonna make a 40mm stack of plate spacers or are you drag racing and your series requires the stud to stick way out?
the only option i know of is arp, they have 60mm and 80mm that fit s13's. i use 20mm spacers on my 60mm arps but if you're feeling inadequate you can get the 80s. the only "problem" is that you'll need new lug nuts, since these studs are 12x1.5.
the 80mm ones are arp part# 100-7713, you can get them from summitracing.com or any other place that sells arp/domestic car parts (they're camaro studs).
did i mention they're gold? that's the #1 reason to buy arp.
JDM Kid 510
jdm_master_X
JDM Kid 510 wrote:Nismo have 60mm one.
http://www.courtesyparts.com/M...PK104
jdm_master_X wrote:I was wondering if anybody makes wheel studs longer than 60mm? I used the search button but couldn't find anything....
can't you f*ckin' read the title you little sh*t??!
nothing you know of that retains the same thread pitch as OEM studs?
sultan
nah
jdm_master_X
will q45 studs fit the s13? q45 studs are longer and i wonder if they will spline perfectly into the hubs i have (s14 rear 5 lugs)
