66mgb wrote:How hard is it to replace a wheel stud on my '92Q?
I had new rubber put on her last week and the mechanic got a little squirrley with the air ratchet and stripped a couple of studs - one on the front passenger side and one on the rear driver's side.
PO'ed doesn't even begin to describe my mental state at this moment!
Stay away from a certain Goodyear Dealer here in Decatur.
For a second there I thought you were in Decatur GA... I would have lent a hand. It's very easy actually. If you bang on the tip of a stud with a hammer, it falls out (soak it with a penetrant such as WD-40 first).
You slide in the new stud from behind on the hub then torque it into place. The base of the stud is not threaded so you'll need some sort of spacer over it to make up the gap.
Honestly, I don't see why you're even doing this since it's Goodyear's responsibility to fix the problem they caused.
..Drew....
