toptechracing wrote:ARP stud you will need to drill hubs and press new studs, Nismo studs press right in and use a stock lugnut. The Nismo studs are a little pricey but way easy to use.
Really? I have ARP wheel studs, and I didn't have to do anything of the sort.
They work just fine. However, the ARP studs are super long. You'll need open-ended lug nuts. They serve their purpose well though, and for the money, they're much more cost effective than the NISMO ones. Just remember that the ARP wheel stud specs are not the same as Nissan. When you get lug nuts, you'll want to use honda spec.
