C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Thu Mar 18, 2004 8:47 am
Wheel stage refers to the size. Essentially, within a turbo size(i.e. T04E or T04B) the outer or major diameter of the compressor wheel is the same. Different trim levels tend to correspond with different inner or minor diameters of the compressor wheels.
A 40 mm wastegate will likely be more than enough for your goals.
You can use some sort of ignition control device, or you can simply loosen the distributor bolts and turn the distributor. Use a timing gun. Keep in mind that doing it this way will retard timing across the board, so you would affect off boost timing as well. Boost dependent timing retard systems are a pretty good option.
The HKS twin power and MSD and the like are nothing more than amplifiers. Some have various other features though and may include a ignition retard system of some sort.
The heat range refers to how long the insulator nose is. This affects how quicklyt heat can be dissapated into the heads from the plug. A longer insulator nose will take longer to cool and run hotter. Too hot and your plug can become a source for detonation to start. Too cold and the self-cleaning natyure of the plugs will be lost and your plugs will foul. IIRC the stock KA plugs are in the 7 the range. With a turbo, a lower heat range is usually a little better to stave off detonation. With a street car, I'd go no more than one heat range lower.Race cars can maybe get away with more depending on how hot the motor and combustion temps are.
