wheel specs
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
stendori
Car: 2010 g37x cuope
hi all, newbie to the forum and to owning an infiniti. bought my wife a new 2010 G37x coupe hold over and was thinking about getting another set of rims/tires for the winter time and was wondering what to get, like if should stay w/ stock size or maybe drop rim size bigger tires to match stock highth? i read the wheel thread on page top but noticed it didnt have the 2010 specs and didnt know if the offsets where the same or what not. thanks
joe603
Car: 2014 Durango R/T
Welcome to NICO! For winter rims/tires, I'd drop it down an inch (unless you have the 17s). Not 100% on the offsets, but the guys should be able to point you in the right direction.
stendori
hey thanks. yea it has the 18" rims. thought about getting 17" rims as they will be cheaper for sure.
audtatious
Wheel specs are available in the G-series F.A.Q at the top of the forum or you can catch them off the Infiniti link in my sig.
stendori
audtatious wrote:Wheel specs are available in the G-series F.A.Q at the top of the forum or you can catch them off the Infiniti link in my sig.
i must have missed the 2010 model specs when i checked that section out. maybe i'll check again for the 2010 g37 coupe to see it. saw other years but just not for newer ones.
audtatious
http://www.infinitig37.com/coupe-wheel-tech.html
Should be:
Front & Rear 18x8 +43mm offset for the X
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
