C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Fri May 15, 2009 9:09 am
You do not need a staggered set up per se. Typically staggered wheels refers to wheel width, but can also refer to wheel diameter. I suppose you might even be able to refer to offset as well. But in the more common usage of the term, you could run the same width all the way around and get it flush with the fender. However, you will likely need different offsets to get the most exact fit.
Spacers are also not necessary. Unless you are considering a wheel with limited offset selections, you simply order the wheel with the correct offset for the desired wheel width and you should be fine. All spacers do is effectively change the offset.
As for lugnuts loosening, I've never heard of that. I've used some on the track and they were fine. The biggest issue from a safety standpoint is to make sure the lugnuts engage enough threads on the studs. The rule of thumb is that the lug not must thread in as deep as the stud is wide. So if a Stud diamter is 1/2", then the lug nut must engage 1/2" of the stud.
If you do decide to go with a wheel spacer, get a good one. H&R sells some that are designed to fit specific cars and in most applications have multiple available offsets. With the thicker spacers, they wil also include its own hubcenter.
