wheel spacers?
Jammin_Quack
Car: 2009 Nissan Altima Sedan
im sure people have used/have spacers, i was wondering what your opinions are? and if its safe to have.
Oilsink
Car: 08 dark slate
theyre perfectly fine, if you go more than 5mm then make sure you get extended studs.
nogears909
Car: 2008 Niagra Grey Coupe 2.5S CVT
or get the ones with new studs already attached
beeristasty
Car: 07 Altima 3.5 SE
nogears909 wrote:or get the ones with new studs already attached
I'd recommend installing extended lugs over using spacers with ones built-in. Why? 5 less points of failure per wheel. Not that it's a common occurrence, but if a lug breaks between the spacer and hub, you probably wouldn't be able to tell with a visual inspection.
Jammin_Quack
ohhh alright thanks for the help guys!
XXplosive990
Car: 2008 Altima Coupe 3.5 CVT
what kind of spacers have members here bought? in other words what are reputable companies that make spacers for our cars
alphapig
Car: Nissan Altima Coupe S 2.5
Ichiba
mmx23z
Car: 2008 A/C 2.5s CVT
sorry to thread jack but i wasnt trying to start another thread, so im in the market for spacers im currently on the SE-R's 18x8 45 offset wat im considering are either 15mm or 20mm's i kno the 15s will be perfect at 30 but want to kno if a 25 offset will stick out too far on our coupes?
nogears909
depends how low you are i think. im running 18x8 with +38 and just put my coils on over the weekend. I was originally going to get spacers, but seeing how it fits im going to stick with that i have. if your drop isint quite as extremem i think u could probably stick out further, ill take a couple pics tonight if i have time to wash it after work
mmx23z
im on eibachs so im not too low...
heres sum pics of my old 18x8 30, 18x8.5 33 350's
& heres my sunken in 18x8 45 SE-R's (with thinner tires as well)
so again i kno 15mm spacers would look good but would 20 be pushing out to far? (25 offset)
