SmithSR »
https://forums.nicoclub.com/smithsr-u5241.html
Sun May 28, 2006 4:31 am
215/45-17 CAN easily clear your front coilovers as long as you:
-have a wheel at +35offset or lower-have not absolutely dumped ride height.
You'll notice that most good suspension coilovers are showing up withe ride height and preload adjustability. This means that YOU decide where the lower spring perch is going to sit. It you're interested in fitting cool wheels to your car, then keep the spring perch just above the shoulder of the tire, and clearance is a breeze.
