Wheel Spacers for M35x
vika123
Has anyone installed wheel spacers on their M35x? If yes, Can you please post the pics and also let me know where I can buy the wheel spacers at?
ThanksV
szh
Car: 2018 Tesla Model 3.
vika123 wrote:Has anyone installed wheel spacers on their M35x? If yes, Can you please post the pics and also let me know where I can buy the wheel spacers at?
ThanksV
What is the specific application need (what offset are you trying to correct) ... so why do you want to install wheel spacers?
The M35X (awd) model is probably more sensitive to suspension modifications than the standard M35, since these changes are likely to negatively affect the ATTESSA drive system.
So ... can you elaborate further?
Z
vika123
Here is what I was planning on doing.
Add about 25mm offset to all 4 wheels to give it a wider look and better handling capability. I have seen M45 owners do it but havent seen one on a 35x yet. Will 25mm cause a negative effect on the suspension and ATTESSA drive system?
Thanks for your help
V
07sportm35
Car: 2007 Infiniti M35 Sport
vika123 wrote:Here is what I was planning on doing.
V
If you do feel like you want to add spacers just do 15mm as oppose to 25mm. Yes it will adversly effect the suspension. Handling will slightly degrade but yes it will look nicer. Doing 15mm will still look nicer than stock and be less intrusive than 25mm on your suspension.
