ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Fri Oct 29, 2010 12:20 pm
When spacing the web of the core of the wheel the wheel moves away from the bearing. The stresses formed are when the wheels are turned and directional forces try to keep things as they were before the turn, things in motion want to stay in motion and want to stay in the direction of that motion. Depending on the spacer you want and keeping in mind the bigger the space the more or greater the difference on the forces applied to the turning direction the wheel assembly travel through. The sharper the turn the greater the force. The farther offset the wheel the more it will reflect bumps in the road and the more the driver has to work and so the power steering.
You want 2" is that 1" a side. You may find the steering at the extreme rotation of the wheel becomes a force to reckon with when returning to zero. It will be trial and error after you mount those spacers. Try a sharp turn then a recover to center then opposite turn.
Your lock up LSD in the rear will not like the added length, but it complains with all stock. When all the spacers are in put in 4WD and slowly do sharp right and left turns, in fact do this take note before adding the spacers and compare a before and after test.
Just noticed you have a 2WD unit, but still do it, if you have LS rear end.
