Wheel Spacer ?
All things Altima Coupe.
D-Roll
Car: 08 Nissan 350Z Touring Coupe
Im looking into getting .250" or .375" spacers for the coupe..and was wanting to know what size spacer I could go with, without having to change out the lug studs.
http://www.baer.com/buy/catalo...s.pdf
or go with wheel adapters like..
Thanks in advance...
08altima35
Car: 08 Nissan Altima Coupe SE 3.5 6Spd Manny Artisan Turbo Dark Slate
to kick you wheels out a little more spacers is what you're looking for. the adapters will change your lug/bolt pattern size and i wouldn't recommend anyone use them regardless of how good of a deal you can get on wheels with a non oem bolt pattern. also beware of using spacers and consider buying stronger wheel studs as your wheel will seat higher up on the studs giving them less strength. hope this helps you out.
edit:also, if you want to get your wheels dead on flush with your fendor tie a nut or a washer on the end of a string and let the nut or washer dangle down while holding the top part of the string to fendor at the top of the wheel well. then take a measurement (metric or standard) from the top of your wheel to the string. take your front and rear measurements to a local tire/wheel shop and they'll get you what you need. should cost less the 30 bucks unless they have to get the spacers shipped and shipping charges apply.
Modified by 08altima35 at 8:50 PM 5/19/2008
D-Roll
Thanks for your input! I was thinking of just going with the .250 spacers..if I want it flush, then I would have to go with 1" adapters.
