Wheel spacer question
Nissan 350z / Nissan 370z technical discussion forum: Maintenance, performance, installations, modifications, how-to's and troubleshooting.
orion4456
Car: nissan 2007 350Z
I have been given 4 Ichiba 15mm version 2 spacers and want to use them. My problem is that I just put ARP 60mm studs on all 4 corners. Can I press the studs out of the spacers and using the supplied low profile lugs secure them on my ARP's or can I press the studs out and place them on my hubs as if they were version 1 spacers? I have never used spacers and know nothing about them and I have not found a solution by searching. If I can use them I will,If not I will sell them and but version 1 spacers. Any help would be appreciated.
audtatious
If there is enough thread on the ARP studs then you can probably do that.
orion4456
Wasn't sure about it but it seemed like it should work, Studs are 60mm so they are about 3 inches long leaving plenty of thread space for the wheels. Thanks for the help I really do appreciate it.
kingbaby
Car: Nissanmobile!
will work
post pics
orion4456
Thanks for the help, will post pics as soon as lugs come.
Return to “350z / 370z Technical”
