hey thanks what if i didnt go with wide replacement fenders what would a good sizing be im really into the look of cars that have the wheels sit flush with the fendersashibah83 wrote:why???learn this fast, you dont buy wheels to fit your wide fenders, you buy wide fenders to fit you wheels, if your set on wide fenders, look for 17-18 inch wheels 9.5-10 inch wide front with a 10-0 offset and 11-13 inch wide rears with a 0 to -15 offset
you will still need spacer to make thse flush, im going that size(Work XT-7's)with stock fenders, if your set on those wheels use a 10-15mm spacers13importuner7 wrote:i just bought a 91 240 with 20mm fenders all the way around. i wish the last guy would have put 50 or 60mm on instead. its a waste of money just for 20mm. anyway im thinking about getting rota p45r's in 9.5" in 17s or 18s with a 12 offset. pretty nice size. i think it should fit nice with the 20mm. does anyone know if im wrong?
hey thanks for the info i gotta look into thatashibah83 wrote:look in the suspension forum there is a sticky at the top for wheel fitment, for stock fenders i would say 17x9-9.5 +20 to +15
dude that looks great and thanks to everybody that provided me info it def helped out alot thanksAZ89two4Tsx wrote:Ugh.....Unless you've got major bank, don't get overfenders. Cheap(er) wheels look really dumb with overfenders, especially when they can be used without them.
Unless, you're looking at companies like Volk, Work, etc.... with some really low offsets, it'll be a waste of your time and money.
Here are the Rotas on stock fenders, no pull, just a roll. Sizing is 18x9.5 +15.
If you don't really like that aggressive of a look, just PULL your fenders a little. Overfenders are not needed.
Link: zerothread/345017
Hope that helps.
your welcomemidnight91 wrote:dude that looks great and thanks to everybody that provided me info it def helped out alot thanks
it is an factory lip but not on that year car. it came off an 89-90 model. i believe it fits without problemmidnight91 wrote:this is off topic but is that front lip factory and are there any rubbing issues with the front under hard cornering
hey thanks i like that lip alot jw though will it crack and stuff like some of the aftermarket body kits?xX RB Xx wrote:
dude that looks great jw tho do you have anymore pics of the car?ashibah83 wrote:i have D2's, 17x8.5 +20 thts about as agressive as rota gets other than the P45R's
