Wheel sizes and offsets
MartyDevol
Car: Pathfinder
I have a 1997 pathfinder and want to use 1987 wheels on it. Here are the specs.
Nissan Pathfinder 1997 3.3i
– Generation: II [1996 .. 1999]
– Market: EUDM
– Power: 168 hp | 125 kW | 170 PS
– Engine: V6, Petrol
– Center Bore: 100 mm
– Wheel Fasteners: Lug nuts
– Thread Size: M12 x 1.25
– Trim Production: [1997 .. 1999]
Tire Rim PCD
215R15 100Q 6Jx15 ET50 6x139.7
265/70R15 110S 7Jx15 ET40 6x139.7
245/70R16 107S 7Jx16 ET40 6x139.7
245/70R16 107S 7Jx16 ET50 6x139.7
Nissan Pathfinder 1987 3.0
– Generation: I [1985 .. 1995]
– Power: 143 hp | 106.6 kW | 145 PS
– Center Bore: 100.3 mm
– Trim Production: [1987 .. 1989]
Tire Rim PCD
215/75SR15 5.5Jx15 ET45 6x139.7
31x10.50R15LT 7Jx15 ET25 6x139.7
235/75SR15 7Jx15 ET25 6x139.7
If they 1987 wheels will work then I will buy the wheels.
Marty
MartyDevol
Car: Pathfinder
Just called Discount Tire and they told me it would fit just fine. The difference would be 5mm and will fit just fine!
So will have new old stock wheels on my car soon!!!
Marty
EdBwoy
Marty, glad you got some clarification from the tire place.
I usually use this online calculator to get fitment info. I like that this particular one also tries to show how it will look in addition to just saying it will/will not fit.
https://www.wheel-size.com/calc/?wheel1 ... m&scl=50mm
Otherwise, direct experience is the best way to gauge. Please post some pictures or in any way keep us updated after you make the changes.
